Took my time, drilled everything properly….damn jacks have nowhere to live. I’m thinking the reverb module needs to live on the other side of the board. Yea?
I find flux makes a huge difference when using wick.What’s the best way to approach this? I tried a (cheap) sucker and some solder wick. Just made myself frustrated.
De-soldering can be tough and you just have to get a feel for it. If you have some strip board or anything else you can solder some leads to it and practice I think that'd be best.What’s the best way to approach this? I tried a (cheap) sucker and some solder wick. Just made myself frustrated.
Solder some solder on the Pad first then straight away use the Solder Wick, Seems to draw up the solder better!!!What’s the best way to approach this? I tried a (cheap) sucker and some solder wick. Just made myself frustrated.
after a 2nd try I've decided to snip/clean out the pads and resolder. there should be enough pin left even if I need to reshape them to fit through the holes.If you just snipped the pins off as close to the board as possible do you think you'd have enough left to resolder from other side? I used a leaf style socket for mine and had to cut the pins down a bit on purpose. See:
Spirit Box w/ Mods
It seems like I was always one part short of finishing this one for months now. I did the fuzzdog mods changing R4 -> 18k, R8 -> 12k, and the Dwell pot to B25K . For me the dwell change is honestly probably useless, but there wasn't really a downside. One thing I did that might be helpful to...forum.pedalpcb.com
It'll be far easier to remove the remnants of each pin one at a time than to try and get the whole thing out. You could also just tack some wire onto the pins like @jimilee suggested above if you end up a bit short.
Good luck and god speed. May the force be with you.after a 2nd try I've decided to snip/clean out the pads and resolder. there should be enough pin left even if I need to reshape them to fit through the holes.
I've been using the Engineer solder sucker as well for the past few month. There is no going back. The flexible tip and the amount of suction makes it one of the most useful tool in my box ...De-soldering can be tough and you just have to get a feel for it. If you have some strip board or anything else you can solder some leads to it and practice I think that'd be best.
I like a solder sucker and use the fancy "Engineer" branded one from Amazon. Lots of people like braid as well, but just find what works best for you. If you start to get frustrated just sit it down and walk away for a while.
