Thanks. I did try fitting a brass sleeve, but unfortunately the knob is still tilted at an angle once the grub screw is tightened.![]()
Potentiometer Adapter Sleeve - 6.0mm/Knurled Shaft to 1/4" Shaft Adapter
Install any 1/4" smooth shaft knob on a 18T split shaft pot with this super-handy brass potentiometer sleeve. Also can be used for adapting some D-shaft pots.lovemyswitches.com
That was my original thinking, but I tried it once before and the leg snapped off. I’m thinking I may have to completely replace the pot.Get under it with a butter knife and twist gently until straight. Then do what @mdc said. That’s the classic move.
I was thinking use the sleeve to stabilize it before inserting the tab. Sorry should have actually said that part out loud errr typed it.That was my original thinking, but I tried it once before and the leg snapped off. I’m thinking I may have to completely replace the pot.
Tynulox 1/4"(6.5mm) OD Brass Tube 0.25mm Wall × 300mm Length × 2Pcs, H62 Brass Tubing Seamless Round Tubing https://a.co/d/ceYLRO4Those sleeves must be made of gold and dodo eggs to justify the price
Anybody have any alternatives?
29 cents at SmallBear. I use a lot of those things, I often superglue in Nomex sheet scraps to fill the split shaft slots. I've used JB Weld in the past as well. Still best practice to line the set screw up with the split when feasible though, IMO.Those sleeves must be made of gold and dodo eggs to justify the price
I've had better luck with duct tape and tie straps!Gorilla tape and Gorilla glue can fix anything.![]()
You know the little tab that you break off to sit the pot flush in the enclosure?
That’s the one…
It’s a snap…
Where’d it go?
Bam! Right up the snout of the ol' Spice Weasel!
It just so happens that, in most cases, the little breakaway tab is the perfect size to jam into the split, thus preventing a knob’s set screw from pushing the split together and wrecking the pot right away or through long-term fatigue.
I've jammed it in and it's usually solid without any additional fuss, BUT...
If you're unsure that the little tab won't stay put or you find a pot with a tab that most definitely shifts around in the split (like the one in the above photos), then just add a dab of solder to keep it in place. This one will require a dab of solder, on either/both side(s), not on top, so the severed tab sits flush with the top of the split, allowing the knob to sit all the way down.
Of course, only do this tab-trick for set-screw knobs, the knobs meant for splined split-shafts don't work so well once you solder the tab in.
I rarely use split-shaft pots, and prefer set screw knobs...
I swear this is true, Orange oil furniture polish works BETTER than WD-40. I had a shaft with a collet that was rusted tight since the 70's. No amount of WD40 would help. I was walking past it one day with the furniture spray in my hand and just squirt it as I walked by. A day later I was walking by and the collet had fallen to the bottom of the shaft!!!!!!!!!!JB Weld is the answer to everything that WD-40 is not the answer to.
I don't remember exactly the wattage, but there's a kind of fuse which the metal caps fits perfectly knurled shaft pots, I used to do this a lot when I started building pedalsThose sleeves must be made of gold and dodo eggs to justify the price
I have had these straighten back up & I have seen them snap like carrots.Hi, does anyone have any tips for straightening bent legs on a split shaft pot like the one below without them snapping off?
