Ctrl4Smilerz
Why do I see some builds use a single stereo (TRS) jack for a mono pedal? I assume this has to do with grounding but can't the seem thing be achieved with a mono jack?
Can totally be chalked up to what’s available either in personal stash or at the vendors. Less likely the pedal has a battery option and the ring of the TRS connects the power supply ground when the cable is inserted. Helps save on battery lifeWhy do I see some builds use a single stereo (TRS) jack for a mono pedal? I assume this has to do with grounding but can't the seem thing be achieved with a mono jack?
They cost the same or close enough for me that I usually get stereo jacks because I find they grab more securely with the additional contact.Why do I see some builds use a single stereo (TRS) jack for a mono pedal? I assume this has to do with grounding but can't the seem thing be achieved with a mono jack?
This allows you to wire it so the battery disconnects when nothing is plugged into the input.Why do I see some builds use a single stereo (TRS) jack for a mono pedal? I assume this has to do with grounding but can't the seem thing be achieved with a mono jack?
i keep selling my TS's and then forgetting why and buying another, and then realizing that i dont like them and the cycle repeatsWhy do we need another TS clone when the original circuit isn’t even all that good?…
The EHX 16-Second Delay can do all that. Nels Cline uses one.Most delays seem to repeat "one note" why not 3? Why not the last 15 second of what you played?
When the batteries start to go, do you press harder on the remote control?![]()
He owned the original two-footswitch “16 Second Digital Delay”I believe Robert Fripp used one (or two) with the later version of Frippertronics too…
Heat?How does a cap get melted? Especially when it's no where near pot legs.
Come to think of it, I can answer your question...at least in the case of one melty cap..my own...So many unanswered questions?! I generally solder components on the other side of the board. Am I doing it wrong? I'm starting to question if I'm breathing right at this point![]()
Depends on where you got them.....see my "Fingers" Build report.....ugh.....found out the hard way. (Note, with the Aion adapters, separate them and don't let them touch.......)Here’s a serious one: when using SMD components (4 J201, for example) that have already been attached to adapter boards, should/can I keep the boards attached to each other and install them in one row on the PCB? Or should I separate them?…
traumatic brain injuryHow do people like Zappa's music? Asking for a friend.
The VFE schematics are pretty barebones. There’s no indication of pin numbering on that schem. The 15v line (I believe) comes from the SPS daughterboard with the jacks, switching, and charge pump. It’s and input to the circuit.Was gonna post a question just like this, logged on and the perfect thread is at the top.
How do I tell which IC pins are which on this schematic?
Another one - I'm not seeing 15v anywhere, including where the schematic says 15v. Curious if that's a problem with my build or with my reading of this.
It’s good, and therefore enjoyable. Very easilyHow do people like Zappa's music? Asking for a friend.
I usually compare the data sheet to the drawing. Vcc and GND, the input (inverting and non-inverting or +/-) and output.Was gonna post a question just like this, logged on and the perfect thread is at the top.
Shaken, not stirred.How do people like Zappa's music? Asking for a friend.
For pins you should just refer to the chip's data sheet, it will show you which pins are ins, outs, and powers.Was gonna post a question just like this, logged on and the perfect thread is at the top.
