I've heard impedance and/or signal noise happens— depending on the intended application— with a non-solid pour, but I'd love to be educated on this as well.
It's generally used for boards that are bent/flexed iirc.
I doubt there's much concern of noise in the frequencies we live in though. There are some quidelines/concerns for routing over it re inductance...
I've seen a similar type of textured pour on MXR pedals I've taken apart. I have a Dyna Comp on the workbench with that type of ground pour and was kinda wondering the same thing.
My understanding is it was developed to mitigate the effect of temperature expansion of different materials (copper and baseboard). It is a thing of the past I guess. You will probably not be designing a guitar effect pedal that would benefit from it.
I have used this approach also for visual effects. If you put route keepout (shape of your preference) on your board you will get this mask dip effect. I made markers around the knob with it using a PCB front panel. It was not very pronounced but a nice textural thing nevertheless.
VFE has a webbed ground pour, and Peter seems meticulously obsessive about stuff like that— doubt he’d do that if it had a negative impact considering he goes overboard on the engineering of everything else
Does your design need to consider trace impedance, EMF radiation, differential signaling, and return paths? Otherwise don’t worry about it. Just don’t have isolated copper pours hanging out alone.
