So if I have this right, You have to have the Amentum Boost on for the Buffer on the Output of the Amentum to make it work?
I have the Simple JFet Buffer on the Amentum output and it does NOT work.
Ok some interesting findings.
WORKS:
General Tso (Thorpy Buffer built in)
Convex (Thorpy Buffer built in)
Oceanid (Cornish Buffer built in)
Cephus (Cornish Buffer built in)
FDIC (Fuller Buffer built in)
Any Klon (Klon Buffer built in)
TC Electronic Polytune3 Mini w/Bona Fide buffer
Boss RV-3 (retail)
Ceasar Chorus
Celsius Preamp
Does NOT Work:
Ember (TC Spark) Boost using PPCB Cornish Buffer daughterboard
Amentum Boost using Simple JFet daughterboard
Heavy Water Dual Boost (Thorpy buffer built in....not sure why this won't work)
Episode Booster
Clandestine Booster
Xotic EP Booster (Retail)
Edit: In the "Does not work" list it is to varying degrees. For instance, the EP style preamps all quiet it down to a low squeal with the gain dimed. So it's doing SOMETHING. The "DOES WORK" list completely removed any squeal at all and it's just "high gain noise".
Without anything in front of it, and the gain dimed, I can get Tokyo on shortwave........
