I actually have one of those, I use it with my wood fired pizza oven in the back yard.
Might make the tone kinda smokey. But if you want that woody tone….I actually have one of those, I use it with my wood fired pizza oven in the back yard.
I wonder if wood fired would make the pedal sound better.....
I stepped up to a lab oven in 2021 after using a toaster oven for years, I wanted to be able to do more than 2 pedals at a time. I got mine direct from China though, so it cost more than a dumpster dive.I'm looking into getting a little powder coating setup.
Spurred by a recent acquisition: I recently dumpster-dove a lab-grade electric oven. Dunno if it works or not yet, but I'm capable of repairing it regardless.
Looking at guns and the like, anybody talked about that cheapie vevor 50kw unit the evil empire sells?
Im a cheapskate, as evidenced by where I grabbed the oven.
Gotcha - so the gun itself can act as a ground, just not the best possible.The grounding from the gun itself would be your best bet but again it’s not going to give the best grounding needed. If you’re having trouble still maybe hot flocking the part will help!
The grounding wire that comes with the gun can be used but it’s meant to ground the gun not the part but it should still work!Gotcha - so the gun itself can act as a ground, just not the best possible.
Haven't started, just getting everything lined up and doing a refresher and waiting of some practice enclosures to get here as well.
I’ve seen suggestions about tying into the house electrical ground via an outlet but that feels like crazy town to me especially since this setup needs to be something I can break down and store when not in use.
Ok -Seems like one of these could work.
Desco Banana Jack Outlet Plug Adapter | Universal Ground Connection | 3 Prong Outlet Earth Connection | ESD Control | Unbreakable Plastic | Adapter - 0.164 in D | STI - DESCO - 09838 (Pack of 2) - Amazon.com
Desco Banana Jack Outlet Plug Adapter | Universal Ground Connection | 3 Prong Outlet Earth Connection | ESD Control | Unbreakable Plastic | Adapter - 0.164 in D | STI - DESCO - 09838 (Pack of 2) - Amazon.comwww.amazon.com
Could you define outlet?Yes, you’re only pouring ground into the outlet it’s not pulling any voltage from the wall. You should be perfectly fine. But I would make sure to use a different outlet for both the gun and part.
From what I read and researched the wire that comes with the gun is meant to ground the gun itself. Pretty much for safety reasons but I’ve never done this myself I’ve always used the grounding wire to ground the part. The grounding that comes with the gun is very very subpar which is why I recommend using a ground rod. I can literally shoot the part without the gun on and only air and will still stick to the part.Maybe I've been wrong about this, but doesn't the gun ground need to be electrically the same as the part ground? Every gun I've used has had a grounded plug with an extra wire to the plug so you can effectively clip your part separately to the outlet ground, and I've never felt the need to use anything else. Maybe I'm just spoiled by always having lived in a house with a decent ground, but I've never even considered driving a separate rod into the ground outside.
Huh, I just consulted the owner's manual for my gun because it occurred to me I never actually did that and I wanted to see what they said about the ground clip:From what I read and researched the wire that comes with the gun is meant to ground the gun itself. Pretty much for safety reasons but I’ve never done this myself I’ve always used the grounding wire to ground the part. The grounding that comes with the gun is very very subpar which is why I recommend using a ground rod. I can literally shoot the part without the gun on and only air and will still stick to the part.
Welp, I've been doing this technically incorrect for six years or so now.Plug in the power cord to your single phase AC outlet. Please ensure that this outlet (or an extension cord, if you are using one) has a good quality earth (ground).
Connect the crocodile clip of the earth (ground – yellow/green) cable to the ground of the premises in which you are doing the coating.
So based on the user manual of my gun (Redline EZ50), the ground clip from the gun's power supply is supposed to be clipped to the ground rod you theoretically have driven outside. My house actually has a dedicated ground rod, it's on the side of the house near where the power mains come into the house, but I have never felt the need to do anything with it.So between the last three posts, the word ground and every possible variation of it has been used about 2,359 times and I’m more confused than when I started.
I don’t have a dedicated ground rod… yet. I could get one of those outlet adapters that lets you pull a ground from a wall socket.
Could I get clarification?
Connect the gun ground to:
Connect the part to:
We broke powder coating!!!So I have no idea what's going on anymore.
