Thermionic Dist Main LED Location?
Cdhgamer
Hi all, I'm a newbie and I got the Thermionic Kit from Musikding, and I'm a little lost on where the main LED that shows outside of the enclosure is wired to. The couple kits I've done so far had the LED drilled right above the board, but the Musikding pre-drilled enclosure has it between the main board and the 3pdt mini board. I thought on the schematic though that I should wire it to the board where I circled near the bottom, is that correct?
Thank you for your time!
I guess I have one more question. Are both of these open/unlabeled pads negative/grounds like shown on the wiring diagram, or is the left open pad next to the red wire a second positive pad?
