Chuck D. Bones
Circuit Wizard
This little gem was designed after the BD-2 Blues Driver. Both pedals are still in production. I found this schematic over on FSB. It shows everything except the bypass part of the circuit. I believe that Q8's source resistor is typo'ed, it should be 10K. The OD-3 contains the same discrete FET-input opamp gain block as the BD-2. Unlike the BD-2, it employs a single gang pot to control the gain. Although there are two gain stages, same as the BD-2, the OD-3's overall gain is lower. Both pedals contain tone-shaping filters distributed throughout the circuit. The biggest functional difference between the two circuits is the OD-3 uses diodes in the feedback loop to perform clipping; none of the transistors are driven to saturation.
Here's a quick circuit walk-thru. Q8 & Q10 are unity-gain buffers. The input impedance is 1M (R33). The first filter is an 88Hz high-pass made up of C29 & R46. This will have very little effect on a guitar's tone, but will attenuate the bottom octave of a bass guitar. R34, R35, R48, C22, C31 & the parallel resistance of R36 & R49 form a -4.5dB notch filter centered at 500Hz. This provides a mild de-emphasis of the midrange before going to the first gain stage. Both gain stages contain diodes in the feedback loop to provide soft clipping. D10 & D11 provide clipping in the 1st gain stage. R51 & C33 roll-off the bass below 720Hz. D9 & D12 are protection diodes that limit the input signal to prevent overdriving and latching-up the FET diff amp (Q13 & Q14). Unless you drive the shit outta this pedal with another pedal, D9 & D12 will never turn on. The DRIVE pot varies the gain of the 1st stage from 16dB to 43dB at 1KHz. The 2nd gain stage is a simple JFET booster (Q15) with diode feedback (D6 & D7). This stage is reminiscent of a BMP clipping stage. The gain is a modest 11dB. C34 rolls-off the treble above 5.3KHz. R26 & C16 roll-off more treble above 2.8KHz. R26 and C16 also load the output of the 2nd stage, further reducing the treble content. The 1st half of the M5218AL opamp is a 15.5dB gain stage. What comes next is intriguing. The 2nd half of the M5218AL opamp looks like the treble half of an active James tone stack with the treble control set at noon. The only parts that are not balanced are C7 & C8. What we end up with is a -4.4dB notch centered at 1.6KHz, which de-emphasizes the lower part of the treble band. Next comes the same TONE control as the BD-2, with slightly different capacitor values (C13 & C17). After the TONE control comes the LEVEL control, followed by the output buffer (Q1). Q4 and Q9 are part of the soft-switching.
What we end up with is a light overdrive. The modest gain, soft clipping and frequency shaping produces a very smooth, natural sounding distortion. The diode clipping is symmetric and produces only odd-order harmonics. Even with DRIVE at zero, there is still some noticeable clipping in the 2nd stage. The only way to play clean is to back-off on the guitar's volume. Maximum output is just under 1.8Vp-p.
One other comment re: the difference between the OD-3 & the BD-2. I consider the BD-2 to be more of a clean boost because it only sounds good (to me) when it's running clean. The OD-3 is definitely an overdive in my book because it sounds good running dirty.
As you may surmise, I have a few mods in the works. Some minor circuit clean-up and I converted the fixed tone shaper in the last stage to an active James tone stack. The TREBLE control is tuned to mimic the original TONE control. The added BASS control provides -7dB cut to +12dB boost at 100Hz. The LEVEL control was moved ahead of the tone stack. No output buffer req'd. Overall gain, clipping and output level are the same as the original pedal. "Schematic Coming Soon"
