Chuck D. Bones
Circuit Wizard
Try removing the cab sim at the end and see if that sounds even better to you.
I did try that before the experiment with the tone control and it sounded better but perhaps a little on the mellow side (everything sounds mellow compared to a stock Azabache maybe). Maybe I’ll try that again, after all this is what breadboarding is aboutTry removing the cab sim at the end and see if that sounds even better to you.
Do I need a capacitor between the middle lug and ground, like in Jawacan's exemple, reply #14 ? If so, what value ?Another place for a treble cut control is right after Q4. Disconnect the 47K and 100K from the 1nF and 39K and insert a B250K pot between the 100K + 47K and the 1nF + 39K.
That's actually 4 questions.2 questions, if I may :
1. No. See pic above.Do I need a capacitor between the middle lug and ground, like in Jawacan's exemple, reply #14 ? If so, what value ?
2. Try using a SPST switch to short out the 22nF cap. See if that works.Where should I put the cab sim switch ?
3. No.At the intersection of Q4, 20k trim and 47k resistor ?
On the schematics, does the cab sim section starts right after Q4 ?
Argh... I am realizing i mixed up C10 and C18.... I will do as you kindly suggested and report.I see what you did wrong with the toggle switch. The switch is supposed to short out C18. Remove the orange lead from C18. Solder that lead of C18 to the switch lug with the green wire on it. Now solder the orange wire to the other lug that has C18 connected to it. In other words, connect C18 to pins 2 and 3 on the switch. Connect green to pin 2 (where it is now) and orange to pin 3. Nothing connects to pin 1 of the switch.
? I don't know. They were supplied by musikding. I didn't have any trouble to bias all transistors. I guess they are unusual ?What's the deal with the trimpots? Why is there exposed metal on them?
100nF, 220nF, will make no difference.Edit : I made a mistake on C10 again, it's supposed to be 220n...
Quik update : For the Cabsim toggleswitch, shorting the 22n at C18 cuts a lot of low frequencies. I thought it wouldn't be as useful on my build as the opposite alternative : adding some low frequencies.Try using a SPST switch to short out the 22nF cap. See if that works.
