I was wondering if someone could tell me how I would wire this up if im using 6.35mm stereo jacks and also wanted to connect a battery snap. any help is appreciated. thanks!
perfect thank you! as for the stereo jacks, I have the barrel-style jacks with 6 lugs. its my understanding that the lugs are TIP, RING, and GRND from top to bottom accordingly. I can just use the lugs on one side, correct?
rather than risk being confused, use your mulitmeter when you have a stereo cable plugged into the jack to identify the tip, ring and ground connections.
thanks for the advice. I confirmed this to be the case with my multimeter. my question before wiring is whether its ok to just use 3 of the lugs which I believe to be fine as this is my first time using a jack like this with 6 lugs.
