brightlight
Im still pretty new and learning some of these tricks, so thanks for your patience! I'm building an Uber Drive which calls for 2 2sc732 transistors, but i had to sub for 2 2n5089's. The base and collector are swapped for these 2 transistors so basically on the 2n5089 I have to swap legs 2 and 3 if looking at the flat side of the transistor.
I'm having a hard time getting the 2n5089 properly seated in the PCB without having the legs touch. I assume it's NOT ok for the legs to touch so I'm trying to be cautious. When I get it into the pads I can avoid them touching but the transistor has to sit kinda high for the legs to not touch each other. Is this all normal or is there a trick to bending the legs here that I'm missing?
