FancyEspresso
I've been working on a dual Pitch Witch and Moonshot Tremolo pedal for my second build, and i need some help troubleshooting both
Pitch Witch
Moonshot
Let me know you want to see the reverse side of the pcb(s) I just didnt want to remove all the hardware unless someone wanted to see it Thanks for y'alls help!
Pitch Witch
- Signal passes through when the effect is on and off.
- Messing with the knobs changes the LEDs rate and it is blinking vs fading.
- when the effect is engaged there is no modulation or delays.
- The internal gain trimpot does affect the volume while effect is engaged.
- turning up the blend knob cuts out the signal - so presumably only the dry signal is working but not the wet.
Moonshot
- Volume knob works - the other knobs don't seem to do anything
- Internal LED isn't blinking and the rate LED is on but not blinking either
