TS-50 from AionFX passes signal, but NOISY!
Alright, my seriously smart friends. I need help. I decided to try something different. This TS-50 pedal from AionFX looks promising and unique. It incorporates three inductors and a DC converter. I finished the build and it passes signal both in bypass and active, but it's NOISY! There's a decent amount of static in bypass, and a ton when active. The static is exacerbated by increasing gain and/or treble.
I tried a different op amp with no success. I checked my solder points for bridges, blobs, and cold joints, and couldn't find any. I reinforced the soldering around the legs of the pots, since I've had that issue a couple of times in the past.
Oh! And the LED only lights dimly. I thought that was strange, for sure. (I thought it might have burned out at one point while I was troubleshooting, so I pulled it, which is why it's not in the pictures.)
Suggestions?
  • ts50_documentation_241101_200212.pdf
A lot of your joints are cold. I know you said you checked for blobs but you may want to check again. Sounds like a bad joint somewhere in the power rail/ground.
EDIT: Check C25/26 out especially, it looks like they may be bridged.
Thanks, bro. I put a new tip on my soldering iron and went over everything again with a fine-toothed comb. I resoldered anything that looked even slightly suspicious, cleaned up blobs, and reinforced a few places. I made sure nothing was bridged, including C25/26. Then I checked again. I'm still getting the same noise, unfortunately. I tried it with my Hum-X (hum remover), which helped a little, but it's still noisy.
Is there any spot in particular that still looks like a cold joint? Or could it.be something else?
Thanks again for the help!
getting better, the pads for C25/26 have too much solder on them still. Try removing some and redoing them. Those are blobs and look real dull, should be nice and shiny. Footswitch pads look sus too. Give your board a good cleaning with iso alcohol and take more pics. It's hard to see with all the residue.
Here are some new pics. Same noise, but it's cleaner.
