Not directly a pedal question, but I know many around here have changed their electric guitar's pickups and/or pickup wiring.
I went to simplify the wiring of one of my guitars (change a 5-way pickup switch to 3-way). The stock wiring basically uses the metal case of the pots as a ground bus. IOW, there are fairly large blobs of solder that connect wires (or the shield braid) to the pot housing.
How do you un-solder these big solder blobs? Holding my iron to the pot or solder blob (even with a generous amount of flux paste applied), didn't get the solder hot enough to flow. There is just so much effective metal volume (pot housing + wire/shielding + solder blobs) that it soaks up all the iron's heat. (Like a PCB without thermal reliefs!)
I suspect if I simply held the iron on the housing long enough, the solder would eventually flow. But I wanted to check here before doing that to see if there is perhaps a better way.
Thanks!
Thanks!
