Uses for a box of MOSFETS?
Not sure, but I can tell you what I’d do. Find the data sheet.
Then find some builds that use mosfets - Catalinbread, stuff with mu amps. Grab data sheets for the mosfets used in those circuits. Compare. If the specs line up, breadboard with your new found mosfets.
I was going to say… add a couple of passives and a pot and charge $200+ each for a “boutique” boost with grit, clarity, breakup, transparency…. (whatever it “”does””)
"No cap, through a homeopathically sealed junction, oxidized metals are conditioned with electrons to effect the field inside each transistor, imparting the users tone with a dialectically material increase in amplitude across applicable audible bands fr fr on god"
