Since this section is called “build reports” I thought to post some wip pictures instead of the finished pedal. This is how far I got currently.
The PCB:
I had to use a stereo pot as mono as when shopped for parts, both tayda and mouser were out of the correct value.
Transistors are Russian, a MP11 for Q2 and two CV7351 for Q4 and Q5. Q4 and Q5 are balancing out nicely at 2.61 and 2.62 of Collector Voltage.
I suspect Q2 isn't leaking enough, but strangely enough, I cannot find leaky NPN transistors. D6 and D7 have also been matched for Vf.
And the drilled enclosure:
The PCB:
