What’s on *YOUR* workbench?
Further along the MadBean Zombii Fuzz build I won in the MadBean PIF contest. And even tho the project calls for a 1590BS or 125B enclosure, I was able to get everything tucked into a 15690B (Ball Silver) enclosure.
Zombii_Fuzz_Fit_Test_01.jpg Zombii_Fuzz_Fit_Test_02.jpg Zombii_Fuzz_Fit_Test_03.jpg Zombii_Fuzz_Guts_01.jpg Zombii_Fuzz_Guts_02.jpg
MadBean's faceplate for this project has some SMD LEDs for placing beneath a pair of clear control knobs. Wiring this up was the most challenging part.
Still haven't gotten to the 'firing up' bit yet. Full build report coming after completion & testing.
Combo the Warlow, Kewpie, and Persica.
I want to do it, but was going to use the Glyph (Pharaoh) instead of the Warlow.
Don't think I have any Persica boards left, but I do have a couple Big Mess Π boards on hand, and an already-populated Spluffer :unsure:
That'd leave one output of the Spluffer free for a clean blend, or something of another flavor
EDIT- I did load up on the new Muffin Crumb Amplifier stages... I could see about maybe cascading seven of em for a Muff War
I love mead.
Fell in love with it when I found a recipe in one of my brother's old biker mags (I must've been 13 or 14), had a about a half-dozen pot-beer recipes, and the mead recipe, too.
The alcohol leaches the THC out of the plant matter so you get a double-whammy with the recipes.
I͈̣̞̰̣̩̰̯̖͎̓͌̏͊̄̓͒̔̚͘ ͎̤͌̈wa̭̱͖̮̓͒̏͡͠ͅņ͉̥̗͇̤̫͆̔̆̇̒̌̂̏̑͢͢t̨̢̛͇̻̪͖̞̙͇̞̄̃̐͆̀̊̅̇̈͐͜ ̬͔̜̝͇̳͔͔̪̦̥͐̐̊͋̌̉̓͘̚͠͝tṑ̮͕͇̼͉̎͋̿͊͟ ̻̠̟̟͓̂̔̆͝͞b̆͜e̮̼̦͖̖̱͗̔̓̅̊̚͘ͅ ̭̟̲̳̒̃̍́p̨͙̀̕͜͝a̡̨͕̗͚̒̃͂̈́̓͢͠r̪͕̣̬̞͖̠̹̬͚͇̠͈̊̇̔͆̆̓͌̔̇͛̔̎̕t̡̡̢͓̯͚͕̗͉́͋̈́̍̿̅̋̏̾̕͜͢͡ ̱̺̰͉̳͉̳͇͒͋͂̓̓͆͘̕o̡̨͉̘̯̞̰̭̾̊̀͗̚̕͘͡f̡̡͉̖̪̳̀̓̋͐͗͐͘ͅ ͚̩̭̙͇̀͑̑͘͠y̞̺̙͈̘̼̓̔̓̊̒̒̈́͢ó͔̟͉̻͙̱͒̃̂̆̚ǘ͎̱̫̞̻͖̯͓͗͛̈́̚͘̕͠r̨̛̹̜̗̫͔̥̫͇̮͒͒͑͐̎́̏́̌͟͞ ̮̻̼̪̩̓̓̔͠͝ṕ̖̳͖̗͈̗͚͌̌͛͌̏̿̊͜ë̦̺͇̞̤͎̓͌͌̿͞d͙̱̻̝̖̙̠͚͆́͋̏̄̿̀̏͘̕͢͟a̱̾l̢̡̥̪̹̝͕͉̜͂̃̾͐͑͐̀͠͡ ͈̒ḅ̨̹͇͍̪̱͔̼̱͑̀̒̾̌̍̄̓̈́̎̀̀͢ͅǒ͔̲̙̥̰̰͉̻͎̳͛͋́̄̀́̕͘͟͞͞a̙͚̟͉̓̎̐̑̅͟r̡͈͇͔͖̦̮͔̃̄͒̀̑̓͗̚d̨͍̱̣͖̣͚̭̩̯̝̦͌͌͋̅̇͋̐͂͊̚̚͞,̧̯̮̻͖̬̤̱͙̭̑̉̍̌̾̄͂̃͑̒̕͜ ̩̙͈̘̱̐̃̇̀͡f̩̭̫̦͓͂̍͐̌͋a̧̨̟͈͇͍͕̼͓͉̳͑̿͑̎̅̒̌̀̅͘̚͢͠ẗ̲̙̩̭́̆̉̑h͎̓e͉̱̙̪͚͓̙̪͚̫̩̔̂̀̓̓̊̊͗́͗́͆͟r̡̹̰̟̻̰͕̠͚̭̺̘̮̫̠͉͊̿̏̈͌̎̂́́̒̏͋͂̀̉͡
w̛̮̜͙͙͍͖͔̜͙̝̐̄̋̂͒͜͠͡͝͞͡h͔̩̱͚̞̞̠̪̱͑̒̂̋̀̌̌̓͌̍̆͟ͅy̢̛͇̲̟͉̫͚̗̽̑̔͆̄́͠ ̡̦̞̗̗̟͉͙́̔̐̑̔͗͂̉ḧ̛̼̖̱͚͙͓͈̰̔̍̏̏̕͢͝͡a̧̨̝̤̻͓̰͚̟̟͓͂͂͌̔̅̄̂̆́̍̀͘͟͜͠v̜͕͉̈́̈͊͢͜͞e̻̮͙̠͖͙͗͊͐̋͊́̅̾͢͢ ̡̧͖͇̑̔͐̐͛ͅÿ̡̼͎͖̒̊͂̍͟o͚͔̮̮̔̈̋̇̚͜ư̤̘̱̯̝͈̥̮̭̻̞̂̈́̀̄̏̊̄̚͡͡ ̻̕f̛̘̫͖̼̠̳̮̦́̉̈́́̋̓͝ơ̪͓͊r̥͂ş̣͇̯͙̺̘̮̯̹͒̂̈̏̾͂̂͌͘̚̕͢ak͉͉̝̥̦̻̩̭͈̼͐̓̈́̇́́͌̌̎̈ē̱͟͡n͔̯̰̰̙̟̤̘͍̞͈̑̽̌̽͛̈̏͒̑̿͘̚͟ ̢͚̱̗̄̎̇̏̓͢m̝̹̉͘ẻ̞͙̠͕̖̗̗͎̗͎̂́͐͌̔̅͑̿͝
Boy I’m batting a thousand today….
Just screwed up 6 tops by not paying attention to the drill hole orientation…should’ve bent them from the opposite side! Now I know what to look out for though!
That’s the worst. I’ve been there. Keeping track of what marks need to be on which side will get you.
I’m excited to see what that hole pattern is all about!
Thats such a good idea. That’s exactly what I’ll be doing from now on!
Usually I’m vocal about new projects but with this one I want to make sure everything fits correctly and can house what I intend it to house before I reveal what it’s for.
I’ll give a hint though it’s geared towards utility…😎
When I'm fabricating anything I always stick a piece of paper tape and use a sharpie to denote orientation. I once put 58 turrets at 12 cents each in backwards. I had to pull them all back out and do over. At least I found out that they are VERY hard to pull out. So, kinda good from that standpoint. But 7 buck$ down the drain....
Theres always something to learn from these moments. Im glad it happened now with the prototypes and although it still hurts, 6 isnt bad compared to lets say an entire batch of them!
