Since I solidified my rig for the first time in a decade and am truly happy with it, I find I'm using pedals less and the ones I use the most I want relay bypass so I hopefully never have to worry about changing a footswitch. Also on modulation and delay pedals, momentary bypass makes for some cool and inspiring use of pedals.Chris, those Aion relay boards look very trick. I'm solidly in the +Aion/Kevin switch board situation but adding relay? Bacon.
That’s purty right there.I've had plenty of working PCBs come off my mill, but last night was probably the cleanest one I've ever made, required zero post-processing cleanup.
Wired up a personal Boneyard-modded Circulator last night. Love at first listen/build a few months ago when I made one as a gift. Rate low, everything else dimed and mode switch set left is such a pleasantly state-altering swoowlsh. Throb LED will be added when it's boxed up, natch
Yes! EQD Grand Orbiter clone. Chuck's mods are incredible!
That’s an OTA phaser? I need one of these in my life.
Bu bu buuu Buuuutttt ...View attachment 100156
I went through the Arnold Bocklin font set and it seems like the I and N are the only problem characters.
Who needs a Big Mork when you can have an Alien Gape?Bu bu buuu Buuuutttt ...
... that "M" still looks like an alien bent over, head on ground, hugging itself, pointing its kiester at you.
