Look at how your opamps are connected. If the negative rail (pin 4 on a TL072 or similar) goes to ground, your Vref is going to be half of your positive rail voltage (VCC). If the negative rail is connected to a negative voltage opposite of the positive rail's voltage, i.e. +9V on pin 8 and -9V on pin 4, then your Vref will actually be 0V, or ground.However knowing when to do so is a dark art and only witches and virgins can tell you.
Very small rocks!Look at how your opamps are connected. If the negative rail (pin 4 on a TL072 or similar) goes to ground, your Vref is going to be half of your positive rail voltage (VCC). If the negative rail is connected to a negative voltage, i.e. +9V on pin 8 and -9V on pin 4, then your Vref will actually be 0V, or ground.
Vref is still half of the total "swing" between the two rails.
What's halfway between 9 and 0? 4.5
What's halfway between +9 and -9? 0
What's halfway between +18 and -9? +4.5
What's halfway between +15 and -15? 0
There's a rhyme and reason behind it.
*Disclaimer - definitely not a virgin, probably not a witch
I weigh as much as like 50 ducks, and am therefore not made of wood.Very small rocks!
Pardon my inexperience, but why are the values not exactly 9V, or 4.5V?Vcc is the positive supply rail within circuit, Vref (voltage reference)- usually half of the Vcc .
Check schematic below
1N5817 drops about 450mV , and the voltage dividing resistors are probably not exactly 47.00KPardon my inexperience, but why are the values not exactly 9V, or 4.5V?
what is continuity?Why do those particular ports set the voltage across the whole port? (I don’t know the terminology, sorry)
