I'd recognize that bench (and logo) anywhere. Whatcha working on Chris?
Guitar pedals, hopefully they make sounds when I'm done. I should have the first one finished tonight.I'd recognize that bench (and logo) anywhere. Whatcha working on Chris?
Anything "original" in design or did you find something out there you hadn't done yet?Guitar pedals, hopefully they make sounds when I'm done. I should have the first one finished tonight.
There is a mix of things I had previously owned commercially, things I had built but regretted selling and some things that I've never played or were made available as diy projects for the first time recently.Anything "original" in design or did you find something out there you hadn't done yet?
I look forward to the seeing the results, especially the "recently available" batch.There is a mix of things I had previously owned commercially, things I had built but regretted selling and some things that I've never played or were made available as diy projects for the first time recently.
There most definitely is that in there, and a few drive pedals sprinkled in.Bring on the swishy swooshy, wibbly wobbly, timely wimey modulation
I've never seen 12mm pots...what are they used for?Couple of boards from Dead Air, some 12mm pots, and some CMOS chips
I'm just using them to replace fixed resistors in cramped spaces. Haven't seen any docs that call for em though. I was originally looking for 9mm solder lug pots, but saw these and thought they were cuteI've never seen 12mm pots...what are they used for?
