Amazon to be honest. I think Mouser has a version too for your next order.I love color coordinating my cables. I also do the same with USB charging.
Where did you pick up that component lead block? I'm due for one and that looks like a useful version.
Have you tried it on guitar? I'm kinda mulling over whether to build the BassDude or the Nobelium. I don't need the lo-z out or anything.It's time to accept that the nobelium is a permanent fixture in the rig. I'm happy to be back to a single plug pedal board situation. View attachment 88930
Not a ton, just a little when i first built it when testing it for functioning. I mostly use my particle accelerator for guitar, in fact it's now a permanent part of my practice and testing set up. I don't see how it could be a bad thing though. Seems to play nice with all the dirty synthy nonsense I throw at it.Have you tried it on guitar? I'm kinda mulling over whether to build the BassDude or the Nobelium. I don't need the lo-z out or anything.
I’ve built both and they’re both fantastic. I run the BassDude as the preamp running into a Fryette power station and it sounds incredible both on guitar and bass.Have you tried it on guitar? I'm kinda mulling over whether to build the BassDude or the Nobelium. I don't need the lo-z out or anything.
@DGWVIhold up has this guy found a way to make the shallow water a bit less subtle?! Member on here?
I realise this isn't on my workbench yet...
Ain't me- I don't mess with circuits, man. I adhere strictly to build docs
oh rubbish this is in completely the wrong thread isn't it?
Also reading that not all 4046 are equal.
Mines a TiDepends on the circuit, but I've found this true of a few different CD4xxx chips.
The Low Tide seems to work best with TI or Motorola 4046. Harris and RCA haven't worked as well, in my experience
What’s nice is I can test by just holding a capacitor in place - I guess an on-off-on toggle and you could have stock and two options!Build report here. Thread also shows off the mini version with the cap on a switch
Basically just increase the size of C27, in this instance to 470p
