I think it's for two wildly different settings but run at the same time to really squash the hell out of everything. All of Roger Mcguinn's 12 string parts on the classic Byrds records were done running through two compressors. The "all buttons in" method of using an 1176 makes all four of the compression ratios run at the same time tooThe Compact and Compact Bass make sense, I've never understood the "Stacked" version though. I've never tried stacking one compressor into another. Nor do I understand why one would want to.
Quite a few famous stacked compression tones.The Compact and Compact Bass make sense, I've never understood the "Stacked" version though. I've never tried stacking one compressor into another. Nor do I understand why one would want to.
for example stacking compressors like 1176 into LA2A is a technique widely used to treat the voice in a recording session, you can find so many vids on the net about this. Doing the same thing for guitars i don't know if it's usefull , maybe it's just marketing to sell more of this pedals? I've never seen a pedal board with two comp stacked honestly.The Compact and Compact Bass make sense, I've never understood the "Stacked" version though. I've never tried stacking one compressor into another. Nor do I understand why one would want to.
That's why you have a booster BEFORE the 12 overdrivesStacking compressors has been widely used with outboard comps during studio mixing for over half a century.
EDIT: People don't always make the most sense when constructing a pedal board. Just because you see 12 overdrives on a board doesn't mean it's useful.
Most of the real estate is for 9mm pots![]()
I believe the Mikrokosmos overdrive uses mm pots. Naturally, YMMV.Where are we going to find 9 pots that small?
Oh wait, you mean 9mm pots.... I read 9 mm pots.
I looked up “worlds smallest trimmers” but now I just keep getting ads for manscapedWhere are we going to find 9 pots that small?
