dan.schumaker
@dan.schumaker already figuring out how to put this in a 1590a with top jacks![]()
If anyone can it'd be Dan.![]()
Bucksears, you switched off your speaker-sim buffering! What's wrong?"The shaft is ray-shielded, so you'll have to use proton torpedoes."
"I'm alright! I'm going to EQ manually!"Bucksears, you switched off your speaker-sim buffering! What's wrong?
Sorry i wasnāt referring to a bad feeling about the project! Was riffing on Star Wars.I realized my DipTrace 1590DD template isn't extremely accurate so I have a bit more room to work with than it seems.
I'm going to try to get the footswitch as close to the center support as possible and see if it's acceptable, otherwise we might have to look into another option like soft switching with a SPST momentary switch so there's more wiggle room.
Regardless, grinding the support column will not be a step in the assembly process. That's just too messy.
But is @Harry Klippton interested?
I had a commercial device like this and it was noisy AF and I hated it
Whuccha gonna call dat'n?
Bottoms UpII've made something similar to a Hedgehog, Down under we call them Echidna's.
Their made from Saw Blades, Rivets, Reo Bar, Scarifier Blade, Dog Spike & Flat Bar with slots for feet :
Hear me out: Spoo-key
