Is the Natas still in the works?I still have a lot of SMD capacitors to remove and measure, but basically it is: Boost > 3-Stage Cascaded JFET Amp sim > 5 Opamp stages of EQ/tone shaping > Output buffer
The boost is not exactly like a TC Pre but I would assume achieving a similar goal.
It's far from a Tubescreamer.![]()
I got all excited when I saw that @Robert was giving these away with a board order, so I rushed out (okay, maybe three weeks later) and ordered some new boards (that I'm never going to get around to building -- at least not until the parts for the aren't available anymore) in hopes that I would get one of these cool PedalPCB cheat sheets. Sadly no, my recent order arrived without the coveted resistor color code.
Was your input and output reversed like mine was?I was about to say... EHX had the decency to top jack my green sovteks back in the mid 90's.
Yep and I kept it that way when I rehoused it like 20 years ago. I've opened it up to repair it an embarrassing amount of times only to remember it's back asswards. It's even labeled. Feels sooo dumb every time.Was your input and output reversed like mine was?
RIP Troubleshooting Forum.
We’ll just have to see then won’t we?Man this was so much easier than the typical build. Didn't even need the Auditorium to test it.
That's never been a problem, has it?but if you can install the components in the right spot (and on the right side of the board) it's almost foolproof.
Looks like the stonedeaf fx pdfDo I even want to ask? What is it?
I distinctly remember having one of these back when I started that my grandfather gave me. Almost identical except it said “Stackpole Carbon” which was based in my hometown and made resistorsI got all excited when I saw that @Robert was giving these away with a board order, so I rushed out (okay, maybe three weeks later) and ordered some new boards (that I'm never going to get around to building -- at least not until the parts for the aren't available anymore) in hopes that I would get one of these cool PedalPCB cheat sheets. Sadly no, my recent order arrived without the coveted resistor color code.
Guess I'll have to rely on old blue...
Now I know how Ralphie felt that fateful day in the bathroom when he was stripped of his innocence and awakened to the realities of the world.
I use this site:I distinctly remember having one of these back when I started that my grandfather gave me. Almost identical except it said “Stackpole Carbon” which was based in my hometown and made resistors
I’ve done that, I also have an app etc. I rarely use either anymore though as I’m at the point where I know most common values by sightI use this site:
Resistor Color Code Calculator
The Resistor Color Code Calculator identifies the value and tolerance of a color coded resistor given its bands colors. Supports resistors with 3, 4, 5 and 6 bands.resistorcolorcodecalc.com
No worries. I was just busting your chops -- I definitely know how to use the internet.Oh no! I'll get one out to you tomorrow.![]()
