They updated to a 2006 layoutI like Stompbox Parts. Decent prices, good selection including some of the weird stuff (dual gang, odd tapers), and they always show up quickly (from MI to TX in my case).
I ordered my non-hardware components from Mouser. So I don’t have much occasion to order from Tayda, and their ‘90s looking website is kinda painful to navigate![]()
This all day long.Stompbox parts mostly. I have lost the will to order from tayda
same.I miss it so badly.![]()
Another Coloradan!There is a dispensary on my way home from work. OH! Not that pot.....
Tayda is great for those. They also have the dust cover/pot condoms for super cheap if you get the alphas.
All of my cases are symmetric (so far) so I usually lay the pots out on the outside of the case, using the case as the holder but not tucked where I have a hard time reachingAhh right, I've never done that because I don't trust that they will fit. I balance the board with the unsoldered pots into the enclosure, and then solder the pots.
Lightbulb moment, that makes so much sense. Got into building a year ago and have orderd mixed alpha/tayda due to availaability, I use the keech design templates for lining up holes , noticed with some builds i had to slight twist the legs to align correctly, its subtle...but subtle to builders is HUGE. Thanks for the tip, looks like ill slowly transition to all alphas. Any thought on the Lovemy switches brand?Stay away from the tayda branded pots and get the alphas.
The tayda brand dimensions are ever so smaller than than the alphas and will throw off your dilling if mixed with alphas.
I tend to just use the SBP pots now and they're great. Not sure that I've ever ordered any real quantity from LMS aside from maybe some one offs.Lightbulb moment, that makes so much sense. Got into building a year ago and have orderd mixed alpha/tayda due to availaability, I use the keech design templates for lining up holes , noticed with some builds i had to slight twist the legs to align correctly, its subtle...but subtle to builders is HUGE. Thanks for the tip, looks like ill slowly transition to all alphas. Any thought on the Lovemy switches brand?
It's not hard. First you get one of the corner pots in, like the top left. Make sure the legs are level, and test fit the board over the pot. Then do same with the top right. Once these two are in you can eyeball the position of the top middle. Then do the same on the bottom row. When you install the pots, do it tight enough that they won't move around on their own but still loose enough that you can rotate them if you need to. Then after everything is soldered do a final tightening. Sometimes you have to bend the legs ever so slightly, but you can look through the PCB's pot holes as you're holding the board over the pots to see which way you need to bend the legs.
There's no extensive testing to back this up but they work well like pretty much everything else they sell.Lightbulb moment, that makes so much sense. Got into building a year ago and have orderd mixed alpha/tayda due to availaability, I use the keech design templates for lining up holes , noticed with some builds i had to slight twist the legs to align correctly, its subtle...but subtle to builders is HUGE. Thanks for the tip, looks like ill slowly transition to all alphas. Any thought on the Lovemy switches brand?
There is a dispensary 200ft from my house, it’s very dangerous.There is a dispensary on my way home from work. OH! Not that pot.....
I bend mine all the time. They don't break very easily. Here is one I bent just to lower the knob a bit to look better in a 1590bIs this not something that could be corrected by straightening the pots into a line after soldering?
Have you seen how Analogman mounts the King of Tone? They'll bend without breaking.
