P pejotlq New member Aug 19, 2025 #1 Hi, I'm new to DIY and have a question. I've searched the forum but to no avail. Check out my image. Where should I connect the SW? Thanks in advance for your reply.
Robert Reverse Engineer Aug 19, 2025 #2 I suspect you want to connect it to the LED pad. Do you have a schematic for that breakout board? If not, just use your DMM to see if the LED pad is switched to GND when the effect is active. If so, that's where the SW pad goes.
