Melba Toast
Hi all,
I populated the board for the newest Woodpecker version (Q1 PF5102, Q2 2N5088, Q3 2N6027) and when I connected it to my testing rig I got signal when the switch is on, but only as a boost and no oscillation or changes in depth from the other two pots. The Level pot is the only one that affects signal. I know this was an issue some people ran into with the older versions of the board that often had to do with the transistors, but I was wondering if anyone else had run into this issue with this version (PCB132 rev2 is printed on the back). I socketed the transistors and have tried multiple transistors at each position with the same results and I'm not getting any of the ticking people often talk about with the build.
Thanks in advance,
MT
Thanks in advance,
MT
