szukalski
The Mojito has been paraded around a bit, but it’s a great circuit and I wanted one on the inventory.
Nothing special to see here, usual build and made a faceplate for it. Used the recommended diodes, only change was to put the boost switch onto a dual relay board. If I were to do it again then I’d just keep the boost on all the time and adjust as required like I do with my Honeybeest.
The pedal sounds great. It fits a similar role to my speedy sheep, a great low gain drive with the option to kick in the second channel for more gain. If you don’t have one, build one!
