Yep. Spinning a lot of plates right now!Set it for DC. Plug in only the power. You're just getting around to doing this now?
It seems not all of us want it done in real time!Set it for DC. Plug in only the power. You're just getting around to doing this now?
Here's a quick lesson.
I'll assume you know how to use the multimeter.
Preset the trimpots to the middle of rotation.
Power up your pedal.
Connect black - probe to ground in your pedal. Usually the ground lug on the IN or OUT jack is most convenient.
Connect the + probe to the drain lead of one of the JFETs.
Slowly turn the trimpot closest to that JFET to get something close to +4.5V.
Repeat for the other two JFETs.
This is just a recommended starting point. Plug your guitar in and play for a while, see if you like the sound.
After that, you can tweak the trimmers by ear if you like. The sweet spot is probably somewhere between 3V and 6V and will vary by JFET and the user's preferences.
Corduroy is a cool pedal.
I didn’t source the J201 myself, they were part of a kit from Musikding.1.5V is way too low. I obtained good tone with the drains around 4.5V.
I don't know where you get your information on how Mr. Wampler biases the JFETs. 1.5V on the drain is HOT because it means higher drain current.
"Big" channel is thru the 2N5089. Gain of that stage is around 40dB, but then it's knocked down to about 25dB at Q2. Q1 makes distortion and is supposed to add a fuzzy tone.
"Tight" channel is thru the LM386. Gain of that stage is around 26dB, but then it's knocked down to about 18dB at Q2. IC1 makes very little, if any, distortion. It's job is to goose Q2.
The BRIGHT pot has the appropriate range on mine. It's supposed to be B25K, what did you have in there before? Verify R26 & R27 are both 15K, C18 is 2.2nF, C19 is 10nF. Do you want it to go darker or brighter?
Did you source the parts yourself or buy a kit?
I believe Interfet J201's TO-92 are in current production through Mouser & it's subsidiary's from around $3.45 each for 10 pieces!At least the SMD parts are still in production. You stand a much better chance of getting good parts when you buy those.
If you want the Holler, it costs you Dollars!!!I stand corrected. $3.24 ea for 10 here in the US. Pretty steep price!
Hey Chuck,Hey, great demo!
If I had to venture a guess based on what you told me so far, I'd say the J201s you bought and the J201s Wampler used have different Vp & Idss. There is a lot of variation from lot-to-lot and I expect that Wampler tests and sorts his JFETs to ensure consistent sound and eliminate the need for trimpots. I doubt that Musikding tests their parts. Most (not all) of the J201s going around these days have low Vp and Idss. There are also a lot of fake J201s for sale and it's possible you ended up with some of those. If you want to explore this further, measure the source voltages on Q2 - Q4 with no signal. Leave the trimpots where you have them set. If your J201s are in-spec, then the source voltage will be between 0.3V and 1.5V.
On mine, the source voltages measured at the low end of the range, between 360mV and 370mV. I ended up with the drains at 3.13V, 3.23V and 5.00V. The trimmers ended up at 16K, 16K and 11K. I'm not saying that's the optimum setting, it's where it sounded good to me. I didn't have an original to compare. The trimpots all interact, so as you know it takes a lot of patience to get them dialed-in. To complicate matters, Q4's trimmer interacts with the output filter (R26, R27, C18, C19 & the BRIGHT pot).
