Harry Klippton
Not Interested
Fair pointYou saying Woody Guthrie didn’t have fun?
Doesn’t all amp/cab have its own tone. What amp/cab are known to be neutral ?I’m of the opinion that most pedals designed to emulate an amp are not good candidates for someone with an existing amp/cab. If you already have a Marshall, obviously you don’t need a Marshall-in-a-box. And I think you’d also have a hard time getting a solid Vox sound from a Marshall as well. Just two different beasts that don’t mix.
I think the best best candidate is someone using an amp/cab rig that is neutral and clean to begin with. That way you can get pretty much any sound you want with the right pedal combo. Seems to me that’s what I’d driving the popularity of these pedals.
Mostly your FRFR kind of stuff. Line 6 and Headrush come to mind but Friedman also has an option. They‘re not traditional amps and cabs. I mean, its amplified sound…but with a different goal in mind.Doesn’t all amp/cab have its own tone. What amp/cab are known to be neutral ?
Ah ok, your talking more powered speakers than guitar amp.Mostly your FRFR kind of stuff. Line 6 and Headrush come to mind but Friedman also has an option. They‘re not traditional amps and cabs. I mean, its amplified sound…but with a different goal in mind.
That line is fuzzy and is only getting fuzzier.Ah ok, your talking more powered speakers than guitar amp.
thanks,
like @manfesto said, it’s kind of blurred. If you’re talking about a Katana or Catalyst then the amp is digitally modeled in the unit itself. With powered speakers, you’re relying on another source to provide the amp tone. Could be a Helix…or it could be one of these new amp pedals.Ah ok, your talking more powered speakers than guitar amp.
thanks,
These are actually digital modelers. The description says:I’m actually pleased to see these new analog amp pedals. Gives guitarists more options. Some guitarists don’t like the idea of going digital so these pedals offer an analog alternative.
Then they’d be competing more directly with the Strymon Iridium and Walrus Audio ACS1, which are exactly that - three amp models (a Fender, a Marshall, and a Vox) in one box.These are actually digital modelers. The description says:
"Built upon powerful dual‑processor engines and UA's proven analog modeling expertise, UAFX Guitar Pedals give you sonic authenticity far beyond other stompboxes."
Like @szukalski said, kind of annoying that they didn't put all the amp models in one box at that price.
I have a hand-wired tube amp with a solid pine cab, 1x12, 30W. Master volume. It sounds amazing indeed. Does the solid pine make a difference? Tone wood?I used to think that tone had to be heavy - and your idea of tone os the sound of a 1959SL Marshall through a quad then yeah, that's gonna be heavy. But I've been getting the best sounds of my life lately through little 1x12 combos. I'll use a boost and/or overdrive and sometimes some delay and reverb, and it sounds soooooooo much better than when I used to gig with a Twin Reverb II! Or any of those heavy amps I used to gig with.
A well built 1x12 tube combo can sound huge. If it's in a solid pine cab it can fill a stage with sound. I have a few, varying from 12W to around 35W and there's not a gig I couldn't do with what I have.
Trouble is it's taken me 40 years to work this all out!
It's this one https://sites.google.com/op.pl/customguitaramps/classictone-brownWell as I make my own cabs these days I feel like I can add a little to the mix - solid pine does help your amp fill a stage.I have built similar cabs from solid pine and 18mm birch ply and it's fascinating how different they are. The ply gives a harder, dryer, 'more focused sound as you might expect. It's more directional because the cab itself isn't contributing as much to the sound. The solid pine cabs I build do tend to have thinner baffles too, because that's how tweeds were built back in the day. The pine, thin baffle, minimal connection points between baffle and cab, and relatively open construction helps a tweed style cab spread the love. In theory I guess it should sound loose and less defined but in practise I find I get all the clarity and definition I need.
What's your amp?
Ah, right. That makes sense. However, I wonder if perhaps there’s some analog compounder the hood. The hybrid approach seems pretty popular these days.These are actually digital modelers. The description says:
Yes, so that was my initial point exactly, I can see that with a modeler system that allows you to tweak your patch you can get a close enough results to compensate for the target amp. However in a pedal, you really need to use something very neutral (DAW, PA, Powered Speakers, etc.)That line is fuzzy and is only getting fuzzier.
Modeling combos like the Boss Katana and the Line 6 Catalyst do double duty - they’re (shockingly good) modeling amps already, but they have “Power Amp” inputs that basically turn them into serviceable FRFR monitors for modelers at very competitive prices.
But Helix users have even been known to tweak their patches to pass a “close enough” signal to a clean-ish amp like a Fender Twin or Roland JC - obviously those amps aren’t FRFR but that doesn’t mean the patch can’t be tweaked to sound “good” even not 100% “accurate”.
Yes I'm in Krakow. I know nothing of amps. He told me it's based on a Princeton but with a Master volume. He brought it over, it sounded awesome, I bought it on the spot. I have no frame of reference but when I played a newish Deluxe Reverb and a Dr.Z Maz 18 I didn't feel they were better. Also my amp looks like my grandma's furniture. Bonus!That's cool! Really interesting to read how a fella on the other side of the world is going on a similar journey to me, but in different ways of course. You are in Poland? Plenty of Polish people here in Australia.Also interesting to hear what he thought of the 5E11 Vibrolux. That circuit is a bit of a favourite of mine. From how he describes his it sounds to me like he didn't quite have the bias dialled in. The 5E11 can break up in a beautiful way. Your amp looks great! Looking at the schematic it looks like he has gone for an AB763 kinda sound but with more focus and mids on tap.
I read that goddam book front to back about a dozen times in grad school as it was a big part of my comp exams and I can tell you from experience that internalizing that book is not great for ones mental healthI don’t know if velveeta is a simulation or a separate thing altogether. Maybe we need to consult Baudrillard.
