Thank you very much!!!
Awesome. I might be able to do this one without having to order any parts.This is what I ordered parts from.
Thank you kindly!Yep, standard 4-knob template.
Stop apologising for your "crude" drawings, you did that in another thread recently, too — the graphics look just fine!Sorry for the crude drawing, just threw it together quick for you.
Really nothing to it, it'll be a breeze, it just looks like a modified Ross Comp or something.
What’s the circuit topology, at a high level?I cannot argue. This one, however, must make up the entirety of that remaining 2% all by itself.
I think I was like 1/2 way through when I finally said f**k it and tossed it back in the box. One day I'll drag it back out, but not today.
For me, this is definitely a case where it makes a lot more sense to buy one. I just got a Magma57 and it's flat out amazing. It made me drop all plans to design a vibrato pedal because I've got something better than I could make for $300.It's hard to say since the schematic is still incomplete.
There are definitely 1176 elements in there, but I don't think it's a component for component clone by any means.
This really is one of those times where you'd have to really want to build this for the experience for it to make sense... If you just want the pedal you should probably just buy one. It's two stacked boards slam packed with SMD components on both sides.
At best, a through hole version would have to be much larger than the original pedal and there are a lot of components in there. I'm at 224 components with plenty more to go.
