vigilante398
Authorized Vendor
Try out the 1M grid leak and let me know how it goes. The 100k carried over from the original Soldano GTO (not SLO) schematic, I obviously have no issue with it being a 1M.
Hey tcpoint , are you using 110v where you are?Well, Get the soldering iron & 1M resistor & get it done, It's 12.48 am in Western Australia & I need some Shut Eye.
I'm making a cup of Tea & buy the time I drink it, I hope to read a Report!!!
That's It!Well, Get the soldering iron & 1M resistor & get it done, It's 12.48 am in Western Australia & I need some Shut Eye.
Yup, if a buffer fixes it that means you're having an impedance mismatch. Buffers typically have a nice high input impedance and a nice low output impedance. Ideally you want a low output impedance from the first circuit going into a much higher input impedance of the second circuit. If the input impedance of the second circuit is too low and/or the output impedance of the first stage is too high, you have a bad mismatch and an unstable circuit.So should I swap out the 100k’s for 1m’s given that having a buffer in front eliminated the issue? @Betty Wont let me know if this solves on yours.
On my builds, the location and shielded nature of any of the wires didn't have an impact on the oscillation at all.I just swapped out the resistor. No worky. I'm going to reroute the wiring from the input and output jacks to the stomp. I will probably have to wait until this evening. I'm going to stick with the 1M resistor.
One more note, The squealing goes away when I turn the volume down on my guitar.
because that resistor doesn't just set impedance, it also plays a role in biasing. I also haven't received feedback re: removing the first tube from the circuit so I can isolate where in the circuit oscillation is originating from.I'm no (tube) expert, but I can't wrap my head around how increasing the input impedance would help prevent oscillation.
This seems like a step in the wrong direction to me.... but I'll refer you back to the first phrase of this post.![]()
They are standard pedal connections. input, pcb input, ground, 9v, pcb out, and output. Removing the whole apparatus did nothing to change my builds' issues. And the Tayda bashing isn't warranted. They are a quality company and I've never had a problem with a single part of theirs over thousands of builds.I don't have a clear picture on what the other wires in those ribbons carry or the function of that secondary pcb outside of switching. I can review any documentation regarding that and see if there's some room for improvement re: lead dress
Well ain’t that a daisy? Who would have thought….https://robrobinette.com/How_the_Saldano_SLO-100_Works.htm in case you want some light reading ...
every amp designer since the RCA tube manuals ... and I'd probably want larger than 1/4w metal films in the attenuating resistors between gain stages, they're dissipating significant percentages of the signal
