The problem here is playing with Tubes & 200v is out of most Members comfort zone!Sure does seem weird when someone who's built literally 5000 pedals is having an issue though![]()
240V ... that number becomes important when you know what the maximum voltage rating is for royal ohm 1/4 watt metal film resistors from tayda and can calculate power dissipation of plate resistors knowing that when you design something you aim for a rating half of dissipation ...The problem here is playing with Tubes & 200v is out of most Members comfort zone!
My post was not to point the finger at anyone or anything, I am sorry if it came across that way. It was not my intention whatsoever.There are Members here complaining that their Pedal is no Good but fail to back it up with Pictures.
Just indirectly point the finger at the Supplier/ Designer when things go South, what a joke!
This isn't even the Troubleshooting section!
I used the MF0W4 from Tayda, max operating voltage is 250V. Plate load resistors aren't going from B+ to ground, they're going from B+ to the plate, so you're not dropping the whole 240V across that resistor. This is why I don't need 250V+ plate bypass caps. The highest voltage I'm reading across any resistor at any point in this circuit is 140V. It's closer to 60% of operating voltage rating so it's above the 50% you would shoot for in high-reliability products, but for a guitar pedal project where the goal is to use easily procured and affordable components I don't have any problem with that.240V ... that number becomes important when you know what the maximum voltage rating is for royal ohm 1/4 watt metal film resistors from tayda and can calculate power dissipation of plate resistors knowing that when you design something you aim for a rating half of dissipation ...
I have had some great discussions with you over the years & I wasn't offended in anyway!My post was not to point the finger at anyone or anything, I am sorry if it came across that way. It was not my intention whatsoever.
I build pedals for fun, it keeps me from going insane sometimes after a shitty day at work. I think we all come together here as we have a passion for the hobby and just enjoy the banter with like-minded folk. I believe we all enjoy the tinkering and experimentation that comes with it as well.
I think we all know that Tayda is not always top-shelf in terms of components but I have never had an issue that I can recall. If I were to build a production pedal I would most likely stick with Mouser or more expensive. But regardless, I myself am not building production pedals and Tayda gives us the ability to get components that work at a good price and at least for me in the US at fairly quick shipping speeds.
I think as usual we will all come together and figure this out, we always do! And that is what makes this forum one of the best I have ever had the chance to be a part of.
Maybe this should be restarted in a troubleshooting forum, so we can pinpoint what is causing the issue.
Just my thoughts...
I think the issue is how you’re approaching the issue. There was one poster that wasn’t at your beck and call both in the thread and through DMs. You suggested that they were negligent by not posting everything you demanded. That was rude and unnecessary.There are Members here complaining that their Pedal is no Good but fail to back it up with Pictures.
Cool, Sorry to anyone if I come across as a rude & pushy regarding this Black Eye issue, just trying to Help.I think the issue is how you’re approaching the issue. There was one poster that wasn’t at your beck and call both in the thread and through DMs. You suggested that they were negligent by not posting everything you demanded. That was rude and unnecessary.
Also, the implicit ad hominem attack on another member who has been extremely responsive in this thread and a very active and helpful member of the community was uncalled for.
I think there may be an issue with your avant garde punctuation. When I see a ton of question marks and exclamation points, that suggests immediacy—that a request is a demand. That may not be the case, but when the same thing is repeated over and over, it seems impatient.
You’re very attentive and helpful with troubleshooting. However, this is an atypical situation since it’s quite different than other pedal projects (i.e., high voltage). This is also @vigilante398’s project. I think they should be taking the lead in diagnosing potential issues. It’s quite dangerous and irresponsible to push folks to start poking around in a circuit they might not be comfortable working on.
Right now, there are some anecdotal accounts of issues that are not present in all builds. @vigilante398 has said they are working to reproduce the issue and will report back.
Nice build!A little while ago in the "Must Build" thread I mentioned my love for the Soldano GTO and was asked if there were any PCBs out there in the world for it. I don't usually work in through-hole, but I decided to take a swing at it. Usually I make a little daughter board for the tube sockets so they can mount at a right angle to the main PCB, but mounting the whole PCB vertically in the chassis like this makes it way easier to build. I'll try to get it boxed up later this month so I can see how it fits, but first I wanted to hear how it sounds. Tayda ran out of the 22nF high voltage caps I planned to use so there's one random yellow film cap, but other than that I'm pleased with the look.
Also I'm pleased that aside from the tube sockets and the ribbon cable, every single part on this board can be purchased cheap from Tayda.
That's up to you. The grid leak resistor (R21) in the original Soldano GTO (I have one now and I got to check firsthand) is 100k, but when I design tube preamps from scratch I use 1M there, so that wouldn't be an issue here. I'm not sure how helpful isolated jacks would be, but it wouldn't hurt anything as long as you still provide some kind of ground connection to the chassis.I was really excited about this project as prior to its existence I was contemplating building a SLO clone or looking to find a preamp project…and boom the black eye shows up! So I immediately got one…. Then the mayhem descended, being a relatively new builder, I held back building it to see if indeed there was or wasn’t a problem… It seems to be a very mixed bag of responses, but none that seem to definitively answer the question (at least for me). I might say goofyhere and there or stir the pot occasionally, but almost never really get heavily involved in situations like this but at this point I feel there is only one way to find out and put this baby to bed… build it… so for those of you in the know be it the creator of the project or just someone in the know, should I build it as per the Build docs(BOM) or should I make any deviations from them? the suggested 1M in R21? Isolated jacks? Specific tubes?
We’re you ever able to reproduce the squealing/oscillation/noise at any volume or gain settings on ether the original GTO or the black eye?That's up to you. The grid leak resistor (R21) in the original Soldano GTO (I have one now and I got to check firsthand) is 100k, but when I design tube preamps from scratch I use 1M there, so that wouldn't be an issue here. I'm not sure how helpful isolated jacks would be, but it wouldn't hurt anything as long as you still provide some kind of ground connection to the chassis.
There is a note about tubes I can add. I was talking to a guy that had built one that was having oscillation problems and I mentioned that the original GTO that I bought came to me with a pair of 12AT7 in it instead of 12AX7, so he tried 12AT7 in his build and it took care of it. Not sure if you would consider that a band-aid fix as the reports I'm hearing of oscillation are only at higher gain settings and 12AT7 just gives you less overall gain than a 12AX7. Just something to consider though if you have tubes lying around and want to try out.
Nope, I built another one and I'm still not having any issues with either of the units I built or the original GTO. I've offered finished Black Eye builds for customers for a couple years and never had issues with them, they just never sold well as most of my customers are bassists so I stopped offering them.We’re you ever able to reproduce the squealing/oscillation/noise at any volume or gain settings on ether the original GTO or the black eye?
Thanks for answering back quickly, I appreciate it, Hopefully I can get it all put together in a reasonable timeframe.Nope, I built another one and I'm still not having any issues with either of the units I built or the original GTO. I've offered finished Black Eye builds for customers for a couple years and never had issues with them, they just never sold well as most of my customers are bassists so I stopped offering them.
One of the people that reported oscillations has offered to send me his build to take a look at, and that should arrive this weekend. I don't know that I'll have time immediately this weekend to check it out, but I will of course let everyone know what I find out when I do.
