Pedalpcb M800
Manuel Ammon
Last pedal built. PedalPCB M800, Marshall JCM 800 type with full EQ section. It's a little bit tricky to dial in the 6 trim pots inside. Did it by ear. Full, raw sounding Marshall sounds. Wanted the look of a JCM 800 did the graphic like that. All pots runs up to 11..... 1660843446816.jpg
ye hast misunderstood, the pedal is 95% built, after i get the last piece or 3 for externals I ask for your guidance setting the inner trim pots ;)
Usually for these kind of circuits you set the trimpots so the bias of the jfet drain is around 4.5V, and then fine tune by ear from there.
Sorry, found a treat in this group, see link below about a PAL800. It's the same circuit. Set all trimmers to 4,5V. Doesn't sound fine to my ears. I dialed in every 6 trim pots by ear. Started at 12.00 O Clock. After 30 minutes dialing in, pedal sounds like a real JCM 800 Marshall.
Hope it helps....
How do you get graphics so opaque? Paper/Ink ? I have big transparency problems on mine... they look ok on pale enclosures, but really bad on darker ones. Ran out of clear ...
Thanks! When you say "2 slides on top of each other" you mean avery over mirror, or two prints on top of mirror foil ?
I'm laser printing, it tends to crack and chip.
Yes, Avery transparent printed foil over mirrow foil. Works perfectly
