I just like the idea having potentiometers running up to 11.Why don't you just make 10 louder, and make 10 be the top number?
These go to eleven.
Thanks, Banzai Music Germany has Fresnel...Fender Champs go to 12.
Seriously gooooood looking build.
Where'd you get the square Fresnel?
Because 11 is more than 10 and makes a lot of fun...
Ordered my kit at Musikding Germany. All parts comes with kit. Look at the bill of materials.Where did you roughly turn the pots to? I have this board waiting for 1/4 in jacks and need a start
Usually for these kind of circuits you set the trimpots so the bias of the jfet drain is around 4.5V, and then fine tune by ear from there.ye hast misunderstood, the pedal is 95% built, after i get the last piece or 3 for externals I ask for your guidance setting the inner trim pots
Sorry, found a treat in this group, see link below about a PAL800. It's the same circuit. Set all trimmers to 4,5V. Doesn't sound fine to my ears. I dialed in every 6 trim pots by ear. Started at 12.00 O Clock. After 30 minutes dialing in, pedal sounds like a real JCM 800 Marshall.ye hast misunderstood, the pedal is 95% built, after i get the last piece or 3 for externals I ask for your guidance setting the inner trim pots
Made a short picture story of one of my pedal graphics....How do you get graphics so opaque? Paper/Ink ? I have big transparency problems on mine... they look ok on pale enclosures, but really bad on darker ones. Ran out of clear ...
Yes, Avery transparent printed foil over mirrow foil. Works perfectlyThanks! When you say "2 slides on top of each other" you mean avery over mirror, or two prints on top of mirror foil ?
I'm laser printing, it tends to crack and chip.
