What's on the workbench?
I've never heard of it, to be honest. It's a signature pedal of some sort.
A friend of mine asked if I knew anything about the pedal, I did not, so I decided to grab one to trace and then send to him afterwards.
Verified moments ago . . . the Rockman Ultimatum Distortion Generator . . . sans the 'low-battery' and buffered-bypass portions with the compressor mod to turn it down. Everything works! (Still need to futz with biasing the compressor mod a bit to dial it in better.)
Used a ±6v DC dual-rail supply instead of the original +12v DC and used four & ½ dual opamps instead of three quad opamps. (Not using the power supply on the Proto-Board. Using a pair of BC modules wired up for dual- 6v rails. [off screen])
The one pot with the split shaft is the original "Volume" control that will be an internal trimmer. Added a final A100K volume at the end of the circuit like a lot of pedals. It gets loud!
(Taking the rest of the day off for Sunday Football and couch-potatoing it for a while.)
