Tuesday where I am!
Oh, another YATS?
Tuesday where I am!
Well, I hope you got it right coz that's a Load of Prototypes!!!!Of course... you know what this means....
Tomorrow is prototype day.... or should I say, the beginning of prototype week.![]()
I’d suggest working backwards.Do you have any idea how long it would take to tag all of those?
Tagging all the ones that aren’t YATS?I’d suggest working backwards.
Tag all dist/OD as YATS, then untag the 15 bluesbreakers, 27 rat/dist+/250 circuits, and the handful of others that are wild enough to have a baxandall EQ.Tagging all the ones that aren’t YATS?
What if it’s a bYATSxandall?Tag all dist/OD as YATS, then untag the 15 bluesbreakers, 27 rat/dist+/250 circuits, and the handful of others that are wild enough to have a baxandall EQ.
I’d say avoid it and just build a shredmaster.What if it’s a bYATSxandall?
is there a shred master pcb? that's a circuit I always meant to build back when I was going thru my Radiohead phase, but I never actually built one. Never seen one in my searches on the store-- no results.I’d say avoid it and just build a shredmaster.
It’s searchable with “shred master”:is there a shred master pcb? that's a circuit I always meant to build back when I was going thru my Radiohead phase, but I never actually built one. Never seen one in my searches on the store-- no results.
ah. I was searching for shredmaster. ill give them both a go at some point. what's the soldat like? I just like the name bc it reminds me of Stravinsky for obvious reasons lolIt’s searchable with “shred master”:
Also, try this one while you’re at it:![]()
I like it a lot. It can provide a lot of bass presence at high gain without getting flubby or loose. So, it has the tightness of a TS that's good for palm muting or high-gain stuff without the attendant loss of low-end. You can use it for other applications, of course, but that's really the key feature for me. Note that the big-box SDT-1 (AC-powered, integrated boost) is the basis for GCI's Brutalist Jr. Although the tone shaping block is significantly modified in Kurt's circuit.ah. I was searching for shredmaster. ill give them both a go at some point. what's the soldat like? I just like the name bc it reminds me of Stravinsky for obvious reasons lol
If I built the Shred Master it would have a Clipping toggle for 1n4148's/ Nothing/Red LedsI like it a lot. It can provide a lot of bass presence at high gain without getting flubby or loose. So, it has the tightness of a TS that's good for palm muting or high-gain stuff without the attendant loss of low-end. You can use it for other applications, of course, but that's really the key feature for me. Note that the big-box SDT-1 (AC-powered, integrated boost) is the basis for GCI's Brutalist Jr. Although the tone shaping block is significantly modified in Kurt's circuit.
Haha, mine has 1x1 Si / 2x1 Si / LEDs.If I built the Shred Master it would have a Clipping toggle for 1n4148's/ Nothing/Red Leds
