SillyOctpuss
They fit on a 6.35mm solid shaft?
The pack I have will fit on a 6.35mm solid shaft. They're on my tele.
Cool. I think I still have a few of these lying around I will give it a shot laterThe pack I have will fit on a 6.35mm solid shaft. They're on my tele.
How does it compare with GPCB's klon? (which has no charge pump, can't recall about the buffer though)Found it on FSB. A klon style od with no buffer or charge pump. Should be interesting.
That, I do not know. I didn’t realize they had one. I haven’t built anything from Barry on a while.How does it compare with GPCB's klon? (which has no charge pump, can't recall about the buffer though)
The brass rings I have don't fit on a 6.35mm shaft without some brute force. After playing some more I don't think this will bother me as much as I originally thought so I'll leave itNice. Good luck
Barry calls his Klone the "MKC", Modified Klon Circuit.That, I do not know. I didn’t realize they had one. I haven’t built anything from Barry on a while.
Absolutely restore this radio.Visited my grandma’s house today and came home with this old transistor radio.
Chock full of ~50 year old WIMA caps! Such mojo!
Y’all think I should clean it up and get it working again, just for fun, or strip out the guts, salvage the many cool tin-can transistors and whatever other mojo parts still have any life in them, and then build a cute little solid state amp into the chassis?
Of the transistors, I’ve only been able to identify one as an af125 and two as af126. Both germanium, though I can’t find much more specs than that.
Edit; also one of these: af178
Can’t read the markings on the other three though
Oh yeah, this one would probably even fit fine in a Jazz Bass cavity. But I think a resonant one would be more fun as an onboard thing, eh?@Passinwind — If your new little unit fits 1590A, that's small enough for one of my bass' cavities... just sayin'.![]()
I'm slowly working through my stash of old onboard preamps etc. with an eye to what might work for you...Yeah, I've got the Black Jaguar Twins (non-identical). One's a passive PJ, the other is an active MM-ish humbucker.
