Bricksnbeatles
Member known well
Got a schematic for the XS Drive?
I ordered a couple of these boards, but I haven't received them yet. I found the BOM online, but how do I know what components go where? Is the board labeled?The Argentum is running at 18v so bias will be at 9v.
I finished mine yesterday, sounds as e expected. Lovely little pedal, really enjoy it.
YesI ordered a couple of these boards, but I haven't received them yet. I found the BOM online, but how do I know what components go where? Is the board labeled?
Thank you. This is my first build without documentation, I really appreciate it.
Absolutely. The PPCB boards are all like that. You can find another board with the same pot layout for a drill guide. Robert uses a basic template layout for his boards. Makes things easier to build.Thank you. This is my first build without documentation, I really appreciate it.
This will be my first time trying to do my own layout on in a larger than called for enclosure as my friend wants something bigger. I'm very excited about this!Absolutely. The PPCB boards are all like that. You can find another board with the same pot layout for a drill guide. Robert uses a basic template layout for his boards. Makes things easier to build.
Is this biased through the trimpots and how do I know when it is biased at 9v?The Argentum is running at 18v so bias will be at 9v.
Many thanks, once again. I apologize for all the questions and I think that should be the last of them.Measure the DC voltage on the drain of each JFET while adjusting it's corresponding trimpot.
You can use either the through-hole or SMD pad as a test point (whichever is more convenient), regardless of which type transistor you have installed.
Do you mean the Tellurian? I built mine off the board values, it's pretty straightforward and low parts count. Awesome sounding low-medium gain drive.Waiting on the build documentation for the Tellarium Drive. Any updates on when that will drop??
Is this circuit sensitive to JFET specs? I usually socket SMD JFETs on an adapter PCB, but I'm tempted to just solder them directly if it's not picky.Measure the DC voltage on the drain of each JFET while adjusting it's corresponding trimpot.
I didn’t find any issues, it’s not a massive gain monster and biased easily.Is this circuit sensitive to JFET specs? I usually socket SMD JFETs on an adapter PCB, but I'm tempted to just solder them directly if it's not picky.
I've tested & used a bunch of this SMD J201 batch, so I'm not worried about them being super out-of-specs or fakes.
How about the 680p...can I use mlcc or do I need a box film cap?There’s nothing special there, and you bias the J201s to 9v. Anything you’re looking for in particular?
I don't think it matters too much, I need to crack mine open to check what I used. I didn't care too much at the time.How about the 680p...can I use mlcc or do I need a box film cap?
Thanks in advance if you get around to it. Looking back on my B.Y.O.C. builds they used a ton of ceramic disks and 0 box film opting for mylar.I don't think it matters too much, I need to crack mine open to check what I used. I didn't care too much at the time.
It doesn’t matter which you use.Thanks in advance if you get around to it. Looking back on my B.Y.O.C. builds they used a ton of ceramic disks and 0 box film opting for mylar.
