eh là bas ma
I didn't build the PPCB version, but I guess it's similar to mine.That Stockade seems like an interesting pedal
5 clipping options (many flavors and a switchable volume boost to compensate volume losses ), 6 positions on the capacitors selector to cut or add some low frequencies. The sound can get very fat, very sharp and everything in between.
You're not toying with some 2 or 3 positions toggles. You get 2 rotary switches. That's a bit more comfortable. Although, there are two toggles for a buffer and a bass boost somewhere else in the circuit.
Gain A is a regular TS gain character, Gain B is an other gain channel, it sounds close but slightly different from A, a bit more modern or complex, i'd say.
Depending on how you set both gain controls, you can play something quiet with moderate saturation, and when ready, engage gain B on the fly, and unleash the gain with more grit.
Three footswitches make it easier to play with the effect and keep strumming on your guitar.
