I have really just lucked out in having the confluence of extra space, the resources, and a wife who encourages it. I was using a small side table and had to pack it all up so the kids didn't get into it every time. Less than ideal until recently. All this setup and not much to show for it. You on the other hand have quite a bit to show for what you have going on.It’s certainly an inspiration to have a setup like that! As is, it’s much better than what I have going on![]()
I can relate to this on so many levels. The things you don’t see are having to clean up and put all my pedals on my desk cause I have no room. Then having to take all those pedals off do some soldering and repeat the clean up process. I may have things to show but with your workbench setup so nicely your workflow must be much simpler than mine.I have really just lucked out in having the confluence of extra space, the resources, and a wife who encourages it. I was using a small side table and had to pack it all up so the kids didn't get into it every time. Less than ideal until recently. All this setup and not much to show for it. You on the other hand have quite a bit to show for what you have going on.
I desperately need to build a table for my old Delta floor model. Something like you have there.
Me tooI desperately need to build a table for my old Delta floor model. Something like you have there.
While my press isn't a floor model I have it on a dedicated stand next to my bench in the basement and I drill a lot of enclosures. I don't see it enough but I can't recommend enough that you make some kind of waste management container to catch as many shavings as possible. I made mine out of a big box and I catch 90-95% of all the crap that would end up all over the place. And every so often empty it with the shop vac.I desperately need to build a table for my old Delta floor model. Something like you have there.
Me threeMe too
Ya, you should see my floor. Gotta clean up all those shavings.While my press isn't a floor model I have it on a dedicated stand next to my bench in the basement and I drill a lot of enclosures. I don't see it enough but I can't recommend enough that you make some kind of waste management container to catch as many shavings as possible. I made mine out of a big box and I catch 90-95% of all the crap that would end up all over the place. And every so often empty it with the shop vac.
View attachment 42131View attachment 42132
Amen. I have been debating a change, but I paid too much for the solderless plugs to just put them to the side. Resale of those plugs is not great.I'm making patch cables, something I really dislike putting together but I want to move away from the solder less cables I've had on my board for the past 5 years. I did seven last night and I have another 7 or 8 to do.
I've been rotating my dirt section extensively on my board recently and I have the d'addario solderless cables and noticed that some of the cables and showing signs of giving up finally so I bit the bullet and said let me make something more robust, especially since I want to start rotating other pedals as well to keep things fresh sounding.Amen. I have been debating a change, but I paid too much for the solderless plugs to just put them to the side. Resale of those plugs is not great.
That has been my issue too. I rotate the pedals depending on my mood or what I am testing. I may create a few dedicated slots on my switcher to rotate pedals and use soldered cables for those locations. That may help reduce the wear and tear and not cost a fortune to change.I've been rotating my dirt section extensively on my board recently and I have the d'addario solderless cables and noticed that some of the cables and showing signs of giving up finally so I bit the bullet and said let me make something more robust, especially since I want to start rotating other pedals as well to keep things fresh sounding.
I've been doing this for years, even when the press was in the garage. Learned it from my shop teacher in the mid 90s.@Guardians of the analog I'm setting up a drill press I bought a few weeks ago this weekend and my god am I glad I saw you post this tip, thank you !!
I have a dust collector, not sure why I haven’t been using it. Maybe because it only takes me about 5 minutes to drill a box and I always remember afterwards.I've been doing this for years, even when the press was in the garage. Learned it from my shop teacher in the mid 90s.
Really love the art!Aldrin Fuzz / Lunar Module aka my “Space Kitty”
I watched a really bad movie the other night called Moonfall with Halle Berry, and the guy that was the Maester in GoT had a cat named Fuzz Aldrin. Made sense.
