							Nice LED placement... At first I thought it was a swollen pickle clone...
It's no ordinary buffer. It's a Elite UNity Amplifier. Which is like a buffer + EQ, but with far better marketing...So @Robert what is this thing? Is it literally just a buffer and some eq? If so their marketing is pretty well it’s just marketing I guess lol
 Doesn’t appear to, based on the pic of the board on the site. Might be easy enough to hack in, but I couldn’t really say without knowing where the loop is in the circuit or if it has many additional components needed for itLooks sick!
Do we know if it has the effects loop?
	Oh yeah I see it now!The loop would be wired offboard using a pair of switched jacks, if desired.
It's completely passive, no additional components involved, and only active when the effect is in bypass.
I suppose I could create a breakout board to assist with the wiring, but in this case it's probably easier to just wire it up without one.
Would you have to put the loop’s jacks pretty low like down by the footswitch, or is there room between the PCB and footswitch?The loop would be wired offboard using a pair of switched jacks, if desired.
