Black Eye build question
drgonzo1969
I just wanted to check real quick if this was correct before I wire it up. Do I have the wires for I/O and power in the right spots?
Red=9v
Green=ground
Black=signal/-
Red=9v
Green=ground
Black=signal/-
Yup, that is it. Plug it in and let it rip.
EDIT: I looked at the picture and misread your post. Your signal and ground wires are swapped. Grounds are on outside, signals should be inside. It's good practice to color things consistently, i.e. don't use black for ground in the DC path and signal in the audio path. That's what threw me off.
