Lil corner of calamity
I appreciate components which are not in little baggies. I love being able to just pull values out of inventory unhindered.Lil corner of calamity
Yes and it need to be built.I'm thinking about starting, well I have started and wonder if I should continue, a Big Screamer Muff Tube pcb design that would let you switch between each phase of the TS and BMP to combine them. Would that be dumb?
Yes, it would be dumb?Yes and it need to be built.
Dude that CNC Milling machine is gnarly! Awesome clean cuts!Cut the tube vents today for my Lab Rat.
Time to order a tube!
Thanks! I wasn’t sure how the cut quality was going to be at the edge of the powder, but it came out pretty good.Dude that CNC Milling machine is gnarly! Awesome clean cuts!
Dude that makes it even cooler! Love the setup man!Thanks! I wasn’t sure how the cut quality was going to be at the edge of the powder, but it came out pretty good.
Not CNC actually! It’s a manual mill from the 60s.
Are you building it for yourself because that’s what you are into? Then others opinions don’t matter… you do you…Yes, it would be dumb?
No dumber than the two Tubescreamers on one board that I built. Make it happen.Yes, it would be dumb?
@Harry Klippton has seven tubescreamers on his board.No dumber than the two Tubescreamers on one board that I built. Make it happen.
That kicks all the asses!Cut the tube vents today for my Lab Rat.
That’s it?@Harry Klippton has seven tubescreamers on his board.
He’s making a new one so we’ll see.That’s it?
