Here’s one version. It appears to be a good choice if you don’t plan to use the faceplate. Otherwise you may not have much clearance. Maybe someone else can confirm how well it works with the faceplate.
Post in thread 'EMU amp simulator'
https://forum.pedalpcb.com/threads/emu-amp-simulator.18554/post-230990
Also, I recently made a drill template based on the template in the build docs, because I plan on using the faceplate. This is currently unverified.
Tayda Electronics Drill Designer for custom enclosures.
drill.taydakits.com
