All of the power supplies are independent, omitting a regulator will only affect that particular voltage.
Still waiting for a Superflare build doc, it's been 7 months since the last request for one...
Have a Whipped Cream OD that seems totally correct but not getting any signal, looking for a schematic/build doc so I can debug. Thanks!!
Hey Again Robert! Can you please upload the schematic for the Equilux? Would like to review before buying the PCB. Thanks again!Buffer on input, gain stage on output. (Both LND150 based)
I'll have the schematic posted in a day or two (although it might already be floating around here somewhere).
Waiting on a monitor to arrive for my desktop computer so I can get back to work on docs.
Thank you so much!![]()
Robert, any chance the Angry Andy Plus build doc will be available in the near future? I already got the pcb from ya. Thinking about tweaking the boost side a little and could use the schematic. Thanks!
Looks like R103Which resistor on the Byzantium Flanger is the LED current limiting resistor?
I use these ultra-bright/high efficiency LEDs that need a bigger CLR. Usually I can deduce the CLR on PPCB boards, but I'm taking the lazy route this time around.![]()
Looks like R103
Hey Robert, just an FYI there looks to be an error in the Nivel Overdrive documentation where it talks about an IC3 (a 2nd LM833) that isn't on the board. Also in the schematic has the IC3 in the power section that should be labelled IC2
I recently looked around for the Barber DD. I saw pics of pcbs with v5 from 2006 and v6 from 2010. So the linked DD schematic from 2013 is probably a higher version than the v2 from the Candid Drive.@Robert - are Candid Drive and this DD schematic identical or are they different versions?
