Wampler Germanium Tumnus!!
I don't think he made a wise decision releasing this Germanium version!
He has to deal with his decision for back then & now for the changes made.
Is the Deluxe next?
Guess what is being released in the next couple of days, I knew it was going to happen!
Considering the pedal is doing a dual clean signal blend, By having about the same threshold the pedal should behave the same. Worst case, add the parallel resistor and it will do the trick (image I found online:)
P.S: NUX did the same https://nuxefx.blogspot.com/2019/06/how-do-we-develop-nux-horseman-tribute.html
Where did you find that response curve? I'm curious about whether or not there was a resistor in series with the signal before it hit the diodes.
