It's there above the ICMissing R5?
Sorry about that, I realized you couldn't see what was going on. I updated it. So, I made a ground plane, ultimately, that's why the ground is so thin.You should make all the traces visible (transparent components?). Now it's hide and seek
Why did you make GND trace so thin compared to signal traces?
Audio breaks up on the treble pot. Good catch, C100 is just for power filtering. For the most part, it can be put anywhere in the first of the power section.First of all - what's the issue with it?
I've spotted one change from the schematic: C100 before R100.
Ok, went through everything with an xacto knife. I have audio now, but it’s very low. I’m wondering if my layout is correct.Have you checked for a short between the solder pads in this area?
Your layout seems to be correct.
You should check the value of R18. Maybe it's 20k? or 200k?
I'd also check signal level at marked points.
Pretty good, how’s it going with you?…So how's it going?
Working on it on lunch and after work today.So how's it going?
Ok, so update. I watched another board without the ground plane and it works. It starts motorboating when I turn up the gain past about 11. It’s got a lot of gain on tap, so I don’t k ow if it’s cross talk on the signal or something else. I haven’t had a chance to audio probe just yet.So how's it going?
