Mouser has almost 1000 in stock at the momentLast time I checked I remember the transformer being hard to find. Will any others work?
Ahah, got it!
I'm 12 hours ahead of Robert down under so that might have something to do with it.???@music6000 - I'm curious, since you're down under in Australia while @Robert is in Georgia, how is it you're seemingly the first to know about new PCBs?
Thanks!Yes it does. The transformer primary faces the top of the PCB.
I need to upload the doc for this one, it should have already been posted.
realized i did this wrong on the bit commander too... so fucking pissed. they still sound cool but man i fucked that up. biggest mistake for me so far, especially since it's two pedals. oh well.damnit
took me over an hour on the captain bit, then maybe 20 min on the octaclave. i think i used half a little roll of desoldering braid. that day i learned about the primary side of transformers! both pedals work great so i can't complain!Go rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrreeeeeeeeeeeeaaaaaaaaaaaaaaaallllllllllllllllllllllllllllllllllllllyyyyyyyyyyyyyyyyyyyyyyyy
ssssssssssssssssssssssssssllllllllllllllllllllllllllllllooooooooooooooowwwwwwwwwlllllllllllllllllllllyyyyyyyyyyyyyyyyyyyyy.
Use lots of copper desolder-braid (with flux) and a MASSIVE solder-pump and bit by bit with plenty of COOLING time in between heating up a pin/pad so as not to lift a trace... It can be done, if you have more patience than I have.
