Coach_McGuirk
I recently bought some blu tack after seeing it recommended a few times. So far, I'm not too impressed. The stuff doesn't stick to itself enough, sometimes leaves residue behind and can be stiff to work with. Prior to ordering blu tack, I was using strips or squares of blue painters tape and overall I think it works better. With the tape, I am able to get enough tack in order to stabilize the parts, and I'm also able to easily see underneath to see if any components are tilted or not flush with the board. With the blu tack, I have to press it around the components and onto the PCB in order to get it to stick enough. And then often times the components aren't aligned properly when I remove the blu tack. Perhaps I'm not using the blu tack properly? Should I be using small pieces or a large piece to cover the whole board?
